CreateEvent() returns 0
Looks like all this moving a discussion from one topic to another only made it more messy...
In that second topic:
@Thoric wrote:
In your Call Library Function Node (CLFN), go to the Error Checking tab and select Maximum. This will cause LV to take extra precautions when calling the dll and might help prevent the crash, allowing you to experiment with different calling parameters etc.
The WaitForSingleObject function does not take a floating point input at the second parameter. Your coercion dot shows that you're asking LabVIEW to coerce a positive infinity to an integer, which isn't going to work. Read the MSDN help on this call to learn that the timeout is in milliseconds, and "infinite" is a special case of 0xFFFFFFF. Use the maximum an unsigned 32-bit value can hold, which is 4294967295. This is the special infinite case.
Maximum error checking didn't help and the code still crushes without any information.
Also using the maximum U32 value didn't solve the problem.
What's more I've just noticed, that calling WaitForSingleObject function causes a plugged camera hang up.
Message 11 of 17
(3,459 Views)
No, it's only messy because you started replying in both threads, contrary to the advice given.
Bill
CLD
(Mid-Level minion.)
Message 12 of 17
(3,447 Views)
Can you see any reply I've posted in that topic? No? Right because I didn't. Can we please leave that issue alone and focus on LabVIEW instead?
I am attaching a piece of code to illustrate the problem.
Message 13 of 17
(3,428 Views)
Accepted by topic author turbolek
OK, I've gound a solution finally. It was all about changing Calling Convention of WaitForSingleObject function from C to stdcall(WINAPI). Seems obvious, but I must have missed it :]
Thanks for your help, everybody.
Message 14 of 17
(3,415 Views)
I can see why you were upset.  I had forgotten that I had already posted about that.  My apologies.
Bill
CLD
(Mid-Level minion.)
Message 15 of 17
(3,402 Views)
You're welcome. Glad you worked it out. Those options are easily missed! Smiley Very Happy
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 16 of 17
(3,395 Views)
I came across a similar issue, thank you for your code. I changed it to make it work on LabVIEW 2017 SP1 + Windows 10, see attached VI. I also improved the UI a bit.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 17 of 17
(3,226 Views)
