CreateProcess by LabVIEW
I am trying to use WinAPI CreateProcessA (kernel32.dll) for future use. I am getting return value 0. What am I doing wrong?
LabVIEW 7.1, XP SP2.
Message 1 of 14
(7,224 Views)
A few comments to answer
1. You can always call GetLastError() in the Win32 API for any function that returns a boolean to indicate pass or fail. It will give you the actual error code, which you can then look up.
2. LV Clusters and C structures are not the same thing. You are trying to pass a pointer to a LV cluster (via the void*) directly to the Win32 API that is expecting a C structure - it is probably getting garbage. Similar issue for the data coming out. In fact, you might end up with corrupted memory...I don't recommend doing this.
3. A much easier approach is to use the .NET System.Diagnostics.Process class, which lets you do the same thing but has full data support in LabVIEW 7.x.
Message 2 of 14
(7,200 Views)
Additionally, I think that your startupinfo cluster is missing two elements.  If memory serves they are dwXSize and dwYSize located between dwY and dwXCountChars.
Paul
Message 3 of 14
(7,197 Views)
Thanks a lot.
I will check it one more time and definitelly will check Process Class from .NET.
Zeck
P.S. 1)  I was trying to use GetLastError() with no luck, it shows NoErorr.
        2)  I created header file to see how LV converts structure and i found that LV is smart enouph to
              produces very similar structure to the code provided by MSDN.
Message 4 of 14
(7,190 Views)
1. Strange! I have no response to that one...
2. Yes, it often is close but remember that "often" isn't "always". At a minimum, for example, LV data structures are 1-byte aligned where Win32 structures are 4-byte aligned. So a structure such as
struct Oops {
   int abc;
   byte def;
   int ouch;
Have different memory layouts, even if the structure definitions are the same.
Let me know if you have any questions with the .NET API's...
Message 5 of 14
(7,187 Views)
Thanks you.
I was thinking about It, but wanted to check with much more advanced people.
So, as I understood, I really have concentrate on .Net. I have never worked with it so, let me read about it and see some examples first.
Thanks again, I will return as I have something or stock with something.
Zeck
Message 6 of 14
(7,164 Views)
.Net is working for me.
Thank you for help.
Zeck
Message 7 of 14
(7,142 Views)
Here is vi with CreateProcessA and GetLastError working.
In order to properly handle stdIn and stdErr in .NET Microsoft recommends to use second (or another) thread but I
could not get enough Information how to do that. Any idea?
Thank you.
Zeck
Message 8 of 14
(7,130 Views)
You actually will do it very differently in LV than you would in C#, simply because of the way LV handles threads.
Exactly how best to handle this is going to depend on what you want to do. For example, if you simply want a thread to sit and read from stderr, the easiest thing to do is create a subVI that takes in the .NET refnum for the process and reads stderr. So I would recommend something like
a. Create an instance of the process class and start the process via .NET.
b. Create a subVI that does the stdin, stdout work - the main stuff you are planning on. Set the VI execution thread to "other 1"
c. Create a subVI that does the stderr work. Set the VI execution thread to "other 2"
d. Execute the two subVI's in parallel - make sure you don't have anything that would serialize the execution of the two subVIs.
Does that make sense?
Message 9 of 14
(7,111 Views)
I decided to try the .net approach. I have never used .net before. I placed a constructor node down but coud not link it to the System.Diagnostics.Process class. I found the class in the list but there are no constructors listed. Could someone help me get a constructor that would let me get to the process class. Thanks.
Message 10 of 14
(6,986 Views)
