Created Service starts with Frontpanel Open
Hi, why do my windows services (created out of an LabVIEW Application)
start with FP open?
I used two methods to create the services:
- FireDaemon
- instsrv.exe & srvany.exe
The service is created correctly but when started the FP appears!
Any ideas would really be appreciated.
Thank You,
Stefan
(3,042 Views)
What you could do is set the state of the Front Panel to hidden.
Ton
My LabVIEW Ideas
(3,036 Views)
Thank You Ton for the reply!
But this would be just a workaround. A service does not have a FP. When it starts with a FP I assume it does not start as services but as an application. I'm going to export the service to an embedded system and therefore I want to be sure that is works as expected.
i used the tutorials
http://zone.ni.com/devzone/cda/tut/p/id/3185
http://digital.ni.com/public.nsf/websearch/21BA0F671A63A60386256CB4004DF99B?OpenDocument
to create the service out of the LV application.
Right now I think I forget any setting when building the exe with the application builder.
Stefan
(3,023 Views)
