Created delayed sine wave output
I'm trying to output a 10V amplitude 10kHz sine wave with a 10ms delay from one of the analog outputs on my USB-6218 but have not been successful yet.  I'm currently using the DAQ assistant to output my generated sine wave waveform using the following program.  Am I doing something incorrectly?  Is the USB-6218 capable of outputting such a high frequency wave?
Thank you.
-rjaeger
(2,552 Views)
 As you can see in the data sheet, your DAQ is capable of a Max Output rate of 250 kS/s. Have you tried with a lower frequency and see if it works? If it does work at say a 2kHz frequency, then your problem is on the output rate. Otherwise, perhaps your problem is in the code.
Good luck!
(2,549 Views)
