Creating Empty Folders in Build Specification
I'm trying to create a build specification that creates sub folders with data required by the application.  This works out ok, but I also want to create empty folders the the app will use for data output.  I can't get the build to createa folder unless there is a file in it.  Is there a way to do this?
TIA,
Bill F
(3,193 Views)
Bill,
Are you trying to create these folders when building the executable?  Have you tried creating an installer?
Stephen Meserve
(3,184 Views)
Yes, I'm using an installer.  But the installer will only install what the build spec creates.  Right?  The empty folders dont show up after you run the build, so they are not installed either.
Bill F
(3,174 Views)
Bill,
I have tried the installation and it will not create a folder unless there is something in it.  Here we have two options.
  1. You can create a dummy file and place it in the "empty" directory.  This will make it non-empty and force its creation
  2. You can create the directory in LabVIEW.  This can be accomplished by following this KnowledgeBase article:
    Programmatically Searching For And Creating A New Directory Using LabVIEW
    http://digital.ni.com/public.nsf/allkb/26743C31FE0CF26786256F16005970A0?OpenDocument
Stephen Meserve
(3,165 Views)
