Creating Executables
 Hi i am using labview 8.6
i would like to make an executable but when i open it from another computer it dosent work,
i have installed the correct version of the run time libaries but it still doesnt work, it is asking for "find the shared libary name nivaiu.dll"
is it possible to make the executable include the libarys? if so how can i do this?
 can anyone help?
(3,406 Views)
Accepted by topic author Labviewuser3
Sounds like it is missing the DAQmx library.  If you want to include that, the easiest (note that I did not say easy) is to build an installer.  It's not that hard (once you've done it a couple of times).
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,403 Views)
i suspected that after i sent the message,
but a confirmation was what i needed
(3,372 Views)
