Creating Express VI from existing VI
I continue to get this Error 1063 whenever I try to convert this subVI to an ExpressVI. Can anyone help me out? I have attached the subVI that I am trying to convert to this posting.
Thanks!
(2,851 Views)
Hi Robin533,
What version of LabVIEW are you using?  What operating system are you using?  Thank you!
Kira T
(2,813 Views)
I am using LabVIEW 2010 professional.
My operating system is windows 7 professional (64-bit)
(2,794 Views)
Hi Robin533,
I am having trouble recreating this problem.  I see the error if I run the VI you attached but can not build a VI where this error appears.  Are you able to build a VI that does the same thing and see the same error?  Are you running 32bit LabVIEW on your 64bit machine or 64bit LabVIEW?  Thanks!
Kira T
(2,781 Views)
