01-10-2006 07:48 AM
01-16-2006
05:01 AM
- last edited on
11-11-2025
06:37 PM
by
Content Cleaner
Hi FNG
What are you actually trying to do with the NI board ?
I have found these links
This is a kb for Audio Measurements
http://zone.ni.com/devzone/conceptd.nsf/webmain/CE46CCEDEBE745FA86256CC3007F9C06
This is a link to another forum which refers to FRF
https://forums.ni.com/t5/LabVIEW/Curvefitting-after-FRF-function/m-p/277279?requireLogin=False
If I am comply of the point please let me know
Hope they help
Tim
NI UK AE
01-16-2006 05:28 AM
01-16-2006 10:50 AM
Hi FNG
I am still not to sure what you are doing but if you are trying to find out what the input signal to the shaker table is then you should be able to link the 4472 straight to the accelerometer.
I am guessing you are using LabVIEW as you have the sound and vibration toolkit. If you are there are lots of example bit of code that you can find under Help >>example finder that will help you with sound and vibration analysis.
Tim
NI
01-17-2006 09:14 AM
01-17-2006 09:30 AM
Hi
Yeah you should be able to, its is just like measuring any other input signal and as all the DSA boards have simultaneous sampling all for will be sampled at the same rate.
There shouldn’t be any problem
Tim
01-17-2006 12:12 PM - edited 01-17-2006 12:12 PM
Message Edited by FNG on 01-17-2006 12:21 PM
