Creating Installer and DAQ-MX: Error Code
How do I screen shot the installer I am including? Is this just the additional installers page?
Message 11 of 30
(1,734 Views)
Yeah just a screenshot of the additional installers page. Did you try it after the reinstall? are you still seeing the same error?
Message 12 of 30
(1,726 Views)
Tried the reinstall, no luck....
Now I am installing the DAQmx drivers that were posted somewhere on this thread.
I'm going to exhaust all the possibilities...
I'll get you the screenshot right after these drivers finish installing.
Horray for losing 6 hours of work installing software + half of last friday on this...
Message 13 of 30
(1,724 Views)
Ok...
so I reinstalled, did the update step mentionned by someone else.
Then I also installed the latest version of DAQmx.
Still no luck!
Any more ideas?
Visit the Request Support page at ni.com/ask to learn more about resolving this problem. Use the following information as a reference:
CDK_Item_OnDoProperties.vi.ProxyCaller >> CDK_Item_OnDoProperties.vi >> AB_UI_FRAMEWORK.vi >> AB_UI_Frmwk_Installer.lvclass:Build.vi >> Installer.lvclass:Build_from_Wizard.vi >> IB_MSI.lvclass:Build.vi >> IB_MSI.lvclass:Engine_AddProductsToDistribution.vi >> NI_MDF.lvlib:MDFDistBuildList_Close.vi
Loading product deployment information
*** Error: Improper function call or command line argument. (Error code -30)
Type 'DefaultFull' of product 'NI Security Update KB5Q5FJ4QW for the LabVIEW Run-Time Engine 8.2' is not found on the source distribution. Insert the correct source distribution or select another product type.
*** Error Details:
Error in MDF API function: _MDFProdPreview_AddProductDone
*** End Error Report
*** Error Details:
Error in MDF API function: _MDFDistBuildList_Close
Error in MDF::DistributionBuildList::AddDependentProducts.
Message 14 of 30
(1,720 Views)
I did find these two KBs that might help regarding error 30.
http://digital.ni.com/public.nsf/allkb/8e5e6c58c625b88a8625786a005b21e0?OpenDocument
This one regarding CVI, but might be useful if you have any .NET calls in your application.
http://digital.ni.com/public.nsf/allkb/5b8a0e1ffdc392fd86257735007c20a4?OpenDocument
Message 15 of 30
(1,712 Views)
My other suggestion would be to try and build the installer without actually including any additional installers and see if you get the same error. If it builds successfully then you can slowly add additional installers and find out what installer is giving the error.
Message 16 of 30
(1,710 Views)
Did that already
It is the DAQmx one that is causing the error.
Cut me some slack...I know the basics of trouble shooting lol...
I just realized I never ran the right Update installer so I will do that now. Hopefully that ones does the trick.
Message 17 of 30
(1,705 Views)
Also thanks for the KBs I'll try both of them.
Also, my master application will have RS 232 * 2 + .net + a DAQmx Ni Card so I'll be needing to get .net working soon enough.
Message 18 of 30
(1,704 Views)
Ok I can't even see the log in the _edit.log file (I've found _edit.log) but I see no such Error code -30 in there...
Can someone from NI help me or do I need to pay for that service?
Message 19 of 30
(1,700 Views)
What DAQmx Driver do you have? The newest one should be 9.5.5
Message 20 of 30
(1,698 Views)
