Creating Loadable Preset Settings
I am trying to create loadable preset settings for my controls.  I wasn't sure of the best method so I started by allowing the user to save the preset as a text file.  The problem I am having is how to load the presets from the text file.  I was thinking that I could try Read from Spreadsheet, but a few problems/questions arise from that.
Problem #1: My text file has two columns.  For the sake of aesthetics I made it so the data of each column was perfectly aligned (Column 1 contains the name of the control and Column 2 contains the value of that control).  This leaves me with instances where different amounts of space exist between elements in the same row.  I am not sure how to parse the data in each row.  The easiest way I can see would be if i could have an offset per line since my control values are all the same length from the start of the line.  I can't figure out how to implement it, if it is even possible.
Problem #2: If I manage to parse the data in the rows properly, I would be left with an array of control values.  How would I go about loading those values into the controls of the VI.  I am not sure how I would do that from an array.
I have attached a text file with the formatting I described above to give some reference.  The file contains channel names with "inactive" next to them.  Those are supposed to correspond with 0's, which I figured I could convert to numbers before they were loaded into the proper boolean controls.
(2,888 Views)
Hello tbergen,
I'd suggest taking a look at the MGI Save/Load Front Panel functions provided in the MGI Library- the functions are straightforward and so are the files themselves if you need to edit them by hand.
MGI Library - Moore Good Ideas
https://www.ni.com/en/support/downloads/tools-network/download.reusable-vi-library-for-labview.html
Tom L.
(2,878 Views)
Accepted by topic author tbergen1
Hi Tom,
Thanks for the response.  I checked out the library and it was pretty helpful.  I ended up figuring out a solution that didn't come directly from the library due to my curiosity.  It is able to read in my files and load the presets to controls.  Thanks for your suggestion!  I attached the VI I made in case anyone stumbles upon this thread with the same problem I had.
Thanks!
(2,831 Views)
