Creating Lookup table in Labview 7.1
well my problem is... i have eperimental data which says
  voltage             distance
  4 to 4.2 mv        6cm
  4.3to 4.5mv       5 cm
  4.6 to 4.8mv      4 cm
so on... there should be a contron which takes my input voltage and give corresponding distance.
i.e. if my input is 4.4 mv the output should be displayed as 5 cm.....
i thought i would implement this using lookup tables, but i m not getting the hang of it....
so could u please suggest me what to do?
Message 11 of 13
(2,151 Views)
I am baffled why the previous posting is not working for you unless you are still using the first quicky VI I posted as a fast example.
Try this zip. In it you will find updates of all of the above VI's.
I have adapted it explicitly for your data. Please watch it run in execution highlighting mode to learn how it works.
What you should see is
1) First the translation table is loaded with your data.
2) A loop iterates and generates random values between 4. and 4.8 mV.
3) Each simulated reading is translated using your table.
4) The raw mV and translated cm values are plotted as two seperate traces on the chart.
Ben
Message Edited by Ben on 04-14-2007 09:21 AM
Message 12 of 13
(2,140 Views)
hey thanks a lot..... its working!!!! 🙂
Message 13 of 13
(2,131 Views)
