Creating MS Access Application with LabVIEW
Hello All,
I want to create a simple database based application for files tracking in a department, which will have a reference no (auto incremental), subject, sent to, date, and other fields.
I want to use LabVIEW as the user interface and MS Access (as it is available to us). Since I have no prior experience with databases, how can I go ahead making this application, which will have searching facilities wrt file nos. etc.
(2,918 Views)
Establish ODBC Connection in your system and use LabVIEW database drivers to access the same.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,914 Views)
Hi Palanivel,
Can u suggest some simple database creation example with MS Access.
(2,896 Views)
