Creating PCM modulator and Demodulator
 Hello!
I want to create a PCM modulator and demodulator.
I want to know what blocks should i use for:
1. Sampling
2.Quantization
3.Binary Encoding
4.Digital to Digital encoding
and vice versa for demodulator.
my input signal is .wav file.
(4,843 Views)
I have done part of that and wonder what bit depth you are shooting for, target sample rate and if this is to be done live and if you are inteinding to have a hardware component to tie together the modulation and the demod setions.
If you are looking to use hardware with 4MHz clock rates, this is not a trivial challenge (aside from the demodulation which amounts to converting a bit stream to plus and minus 1 then down-sample based on the bit depth)
Please share what you have done so-far.
Ben
(4,800 Views)
Sorry, but i am totally new to LabView so you can consider that i haven't done anything yet. 😞
(4,794 Views)
In that case all I can offer is to suggest that you start going through the LV tutioals and on-line courses and then look the;
Graphics & Sound >>> Sound >>> Files
pallette where you will find functions to read and write .wav files.
Ben
(4,791 Views)
thanks, i will start from here.
(4,788 Views)
