Creating Property Nodes For A VI Server Class
How do I create on the block diagram a Property Node for a VI Server Class?  I know how to create Property nodes for front panel controls and indicators but what if I wanted to create a property node for a VI server class to change the VI Description, Front Panel title, etc...Thx
(3,153 Views)
The property node/invoke node change based on what is wired to them.  If you wire a VI reference to them they change to be a VI.
You can also do it by right clicking and selecting the VI class.
You can also do it by selecting the property node, issuing QuickDrop (CTRL + Spacebar) then type "vi" (without quotes) and press CTRL + B.  This also works for other classes but be sure and spell it correctly.
(3,134 Views)
