Creating Serial Digital Waveform Data
All,
I have to create a serial interface for a project I am working on.  This serial data is being created from an array of 16 bit integers being read in from an XML file.  I have had the darndest time figuring out how to turn this 16 bit integer into a single line serial data stream.
I thought this would be an easy task, and I was surprised that this question hasn't been asked and answered already in this forum.
With the help of a NI FAE that rolled through town (Thanks Justin!), we came up with this solution.  I thought I would post it here to aid future users.
The real problem I had to work around is that the digital waveform creation object wants a 2D array to populate waveform.  I still don't have any idea why a 2D array is necessary.
Anyway, this is my solution.  I hope people find it useful. And if there is a better way than converting from U16 to Boolean to Array of 1:0's to 2D array to WFM, I would love to see it.
(2,967 Views)
This?
Although changing the mode from LSB to MSB doesn't seem to work...always stuck in LSB mode....bug maybe?
And you need 2D data because row = sample value and column = signal.
(2,950 Views)
Thanks Bill.
I understand
(2,934 Views)
