Creating Spaced array in Labview
I have a question regarding "creating a spaced array" in LabView using this following math script.
Dt=diff(t1);
dt=mean(Dt);
tStart = min(t1(1),t2(1));
tEnd = max(t1(end),t2(end));
tEqui = (tStart:dt:tEnd)'
 where, t1 And t2 are timestamps from labview.
Thanks in advance.
(4,512 Views)
Look for the ramp function.
(4,504 Views)
Is this the way to do?
Akash
(4,471 Views)
I don't think you need that FOR loop around the Ramp Function.  You could also replace some of that Math Script with real LabVIEW code to get some performance boost.
(4,443 Views)
hey,
can I know which array function you used in that code?
I couldn't find it.
and I have attached the m-file of the project I am working on trying to convert the Matlab code to labview but getting errors as I am analyzing dynamic data.
so any way you could just give pointers about these functions from m-file in converting into labview code:
 ind_nonunique=find(diff(time)==0)+1;
nFFT = 2^nextpow2(2*n-1);
Xc = real(ifft(X.*conj(Y)));
Akash
(4,433 Views)
Which one?  I have Delete From Array, Array Max & Min, Build Array (which is resizable), Derivative x(t).vi, and Ramp Pattern.vi.
(4,407 Views)
yes I figured it out. it was delete from array function.
Akash.
(4,402 Views)
