Creating Word Report
I require help as to how to create table with perfect column width.
Please see attached word file. File has two tables. I need the second table to neatly sit beneath the first table. That is the alignment of columns should be perfect. How to achieve this with word report VIs. I am using LabVIEW 2016.
Thank you
Hema
(2,487 Views)
I think that this will be (very) difficult.  Have you considered creating an Excel Report, where columns are a "natural" feature?  There may still be trouble if you need to "structure" the Spreadsheet (i.e. specify the column sizes), but in Excel, you can open an existing, pre-formatted Workbook and simply add data in the appropriate pre-formatted columns and rows.  It might help to make your Template (what the RGT calls the XLS file you start with) include the Column headers, so your "Report" only has to concern itself with the rows of data.
Bob Schor
(2,442 Views)
