Creating a 100ns pulse with FPGA
I was wondering if I can output 100ns pulses with my PXI- 7833R. I need to output a pulse upoon the rising edge of another signal and the pulse width need to be about 100 ~150ns. Do anyone know how can it be done?
Thanks.
Fw
(5,506 Views)
With the 7833R, this should be rather straight forward. For example, you
could wait on the rising edge of a digital input before proceeding to a
single-cycle timed loop (SCTL). At 40 MHz, the SCTL will have 25 ns
resolution. You can set a digital output high for 4 to 6 cycles.
> done?
(5,470 Views)
Fw
Here is one way to generate a pulse.  This will generate an edge, delay 100nS, generate the opposite edge.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
(5,374 Views)
