Creating a DLL using LabView for use in a C++ application that contains Imaq Vision VIs
Can I create a DLL using LabView for use in a C++ application that contains Imaq Vision VIs.
I have a image processing algorithm that uses vision vis.  When I build into a DLL, the C++ app gets nothing.  No errors.  Nothing.  It simply does not work.  The target machine has a valid runtime vision license.
(3,308 Views)
Hi Tinman,
You should be able to create such a DLL.  I'm not sure exactly why you are seeing the behavior that you are seeing.  One thing to note is that you can program directly in C++ using IMAQ and Vision.  You can find the function reference help by going to Start»Programs»National Instruments»Vision»Documentation»NI-IMAQ»NIIMAQFunctionReference.chm
Also, I am curious to know if you are able to get any DLLs built in LabVIEW to execute in C++.  Have you had similar issues with simpler programs?  If there is a deeper underlying cause, simplifying the program would help point out the cause of problems.  Try making something very simple, like a control and an indicator, and see if you are able to call this.
Wes Pierce
Principal Engineer
Pierce Controls
(3,265 Views)
Hello
Yes I have made simple DLLS in LabView that can be called by C++.  I can pass in arrays, modify them etc..  All is well.
If I use any IMAQ Vision VIs the DLL builds fine but it does not work.  No errors.  No blow ups just nothing.
I have written several test DLLs. The latest one is simply a wrapper for Get Centroid VI.  I take an array of unsigned bytes, and the rows and columns.  I change the array into a 2d array using the row and column ifo.  I create an Image in the DLL Vi, then I convert the 2d array to an image.  I then pass that to Get Centroid.
This is just a simple VI to prove to management that LabView can do this.  The vision VI we will wrap is much more complex.  Rewriting this in C++ using Vision functions would take some time.
(3,254 Views)
Hi Tinman,
One thing that you need to be sure of is that you have the correct versions of the LabVIEW and the Vision Run-Time engines installed.  It sounds like you have the correct version of the LabVIEW Run-Time engine installed, since you were able to run a DLL that you created without Vision.  I would make sure that you have the version of the Vision Run-Time engine installed that matches the version of NI-Vision that you used to develop the DLL.  You can go to Drivers and Updates on the NI website to search for the Vision Run-Time engine.
Wes Pierce
Principal Engineer
Pierce Controls
(3,237 Views)
