Creating a DSN programatically
Hi there,
I'm trying to use the SQL toolkit for LabView (Win9x). I want to
distribute my applications, but I want to save the end user the hassle
of going through the Control Panel>>ODBC.. window to setup the DNS for
the databases in the application.
I know there must be a way, 'cause the SQL toolkit does this when
installed. But is it through the system reg? Some INI file?
Leopoldo Pena
G.P.M.I. Ingenieros
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,041 Views)
I have the same problem. I want to create a database in my vi, in a way that is transparent to the end user. Is there a way to do that??
(2,942 Views)
