Creating a DSN programmatically
Basically, it checks if that entry exists, if exists it doesn't create again, and if it doesn't exist it creates that entry.
ToNi.
Message 11 of 12
(1,245 Views)
As another option, you could try creating a .reg file (that's a registry script file) and run it to update the registry. You can see the format of such a file by exporting data from the registry, but if I remember correctly, the format changes between different windows versions, so you should watch out for that.
___________________
Try to take over the world!
Message 12 of 12
(1,179 Views)
