Creating a LabVIEW Shared DLL for use with C# and Strings?
Hi All,
I am trying to create a prototype for a LabVIEW Shared DLL that all the VI does is take in a string and return an upper cased string. Needless to say the DLL builds fine but when I try calling the shared DLL from C# the .NET application recieves an exception about "Ansi char arrays can not be marshaled as byref or as an unmanaged-to-managed parameter". Does anyone have an example of how to pass a string to a VI and return a string or an example of a better way of accomplishing this.
We are using labVIEW 7.1 on Windows 2000.
I am in quite a bit of a hurry to prove that this type of a LabVIEW Shared DLL VI would work. The eventual system will be passing in a string of XML with a large amount of
data and returning XML.
Thanks in advance,
Jim
(3,148 Views)
Hello jprucha,
This occurs because LabVIEW DLLs are not considered managed code. As such, we need to define the C# function as unsafe to be able to call unmanaged DLLs.
You can find more information about C# and managed code at Microsoft's developer website linked below.
MSDN Home Page
Good luck with the development,
Matt F
(3,148 Views)
