Creating a Sine Wave Chart with Continue if True
I want to create a simple sine wave chart using a while loop and using the continue if true mode. I want to use a Not icon to accomplish this. I also need to have a stop button that a user can press to terminate the process. I have attached my initial sine wave chart using the stop if true and my attempt at accomplising the continue if true.
Thanks for any help!
(3,165 Views)
It sounds like you want the loop to continue if the stop button is NOT pushed.  Does this give you a hint about how to write your program?
(3,118 Views)
