05-22-2013 11:22 AM - edited 05-22-2013 11:23 AM
Hey guys.
I currently have a 200-400MB of data in TDMS format.
I want to create a vi that can show the above data like DIAdem does.
In DIAdem, you can display tons of data on a graph, without the software telling you "you are out of memory"
And once you display the data, you can zoom in on certain area to display more data of that region.
I know waveform graph has that ability to zoomin, but it doesnt give you the ability to programmatically
acquire the width of the data and so on.
So basically I am trying to do the following
1. Create a VI that can display data of a TDMS file without loading all of the data onto memory.. causing errors.
I was thinking about picking one data out every few hundred data... so I can get the rough image of the entire data, without loading everything.
However this takes a lot processing time apparently.
2. Zoomin on a graph and get the width of data.
Is there a better way than using two cursors and programmatically calculating the position of them?
If anyone has example VIs, that would be great.
05-22-2013 12:09 PM
Anytime you are redeveloping existing software you have to ask your self if you don't mind spending all the time in developing, and troubleshooting it, rather than just paying the license. I realize you don't want to reimplement all Diadem functions but this is still something to keep in mind.
You probably have already found it, but checkout the TDMS File Viewer. This shows how to open data, graph and zoom it, and only read a chunk of the data and not the whole file.
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
05-22-2013
12:46 PM
- last edited on
05-08-2025
01:39 PM
by
Content Cleaner
I don't think you really want to duplicate all DIAdem functionality, just find a way to handle large datasets more gracefully directly in LabVIEW.
As a first step, you should start reading here.
I am unsure on your exact details. How are you reaading the TDMS file? The file structure is documented, so you can access any data subsection directly, without having to load the entire file into memory. How smooth is your data? If it is relatively well behaved, all you need to do is read as many points as you have pixels on your graph.
You can zoom with mouse events(mouse down, mouse move, mouse up) directly. During mouse move, you can even draw a dotted rectangle using the "plot images" feature.
06-11-2013 11:09 AM - edited 06-11-2013 11:09 AM
Hi guys.
Thanks for your help. I am always amazed how fast you guys reply and how helpful you guys are.
>Hooovahh
Yea I just want parts of the DIAdem function to be used in LabVIEW.
TDMS File Viewer loads the entire TDMS file so it doesnt really work.
>altenbach
Thanks for the article. I didnt know TDMS does not load the entire file if specified correctly.
So now my question is how to create a decimated set of the original TDMS file in a nice fashion.
I tried decimating it manually... but depending on the file size, things take forever.
Here is the VI and an example TDMS file.
06-11-2013 12:10 PM
No it doesn't. Click on Settings and choose to only load so many samples per channel.
06-11-2013 12:22 PM
I want to say it defaults to the first 1000 samples of the channel(s) selected. Will need to play to make sure.
06-12-2013 09:16 PM
No, TDMS File Viewer won't load the entire TDMS file. It only loads specified data when you click a specific TDMS object (file, group, channel) and by default only the 1000 samples is loaded instead of all the samples. LabVIEW has many performance optimization in TDMS File Viewer, thus I recommend you to investigate TDMS File Viewer instead of doing everything from scratch.
10-21-2013 09:34 AM
Hi doradorachan,
As an alternative to the TDMS File Viewer, I would recommend a tool called Scout:
It's a free tool for viewing TDMS files. It was originally inspired by the built-in viewer, so it contains some of the same features for handling large files. However, it has several extra features that may speed up your analysis, such as built-in cursor math.
Feel free to let me know if you have any questions or comments about this application.
-garrett
