Creating a VI that requires any (x-1) of x outputs.
Delete the broken subVI and copy/drag down one of the other ones and wire it up and it is no longer broken.
Message 11 of 13
(644 Views)
Apparently that bug has been fixed for LV 2018.  When I open it in LV 2018 beta, it's not broken.
Message 12 of 13
(638 Views)
It doesn't appear to be broken in 2017 SP1 either.
Rather than using the Select nodes, it would be better to use "Types Must Match", with the inputs all Variants by default.  The reason being that, at the moment, the VIM doesn't work correctly if an array is wired as an input.
Message 13 of 13
(629 Views)
