Creating a continuous updating array of the most recent "x" samples?
Is there a pre-made function that does this already? Haven't been able to find anything. Basically what I'm trying to do is send an array of data points to the Extract Single Tone VI so I can get the phase angle and then get the difference between the voltage and current waveform angles and then calculate power factor. But I'm not sure how to go about creating a continuously updating array ðŸ¤”
My example says 1000 samples but that might not be enough, not really important because I can adjust that easily.
(1,068 Views)
Hi David,
read the help for PtByPt-DataQueue…
(1,037 Views)
