Creating a desktop shortcut for a Real-time application
I have a couple of real-time projects that I run and would like to create a couple of desktop shortcuts to launch and deploy the application.  I use the same real-time target hardware for a couple of different applications so I go into LabView and open up which ever project I need and then run and deploy the VI from within the project.  It's just a pain to open the project and then scroll down the list of subVi to find the main VI to start my application.  I have created .exe files for non-rt applications and then created a desktop shortcut to run them.  Is there a similar way to create desktop shortcuts for rt applications?
Thank you for the help.
Danny
(2,673 Views)
Danny:
I don't believe there's a way to make a shortcut to an RT exe like you describe. The closest thing I can think of would be to create a PC EXE that will deploy the desired code. Then put a shortcut to that application on the desktop.
Caleb Harris
National Instruments | http://www.ni.com/support
(2,637 Views)
