Creating a dll with NIScope access does not work. Any sugestions?
I attempting to create a dll that I can call with LabView using the “Call Library Function” primitive.  I created a “scope vi”  that allows me to read back the waveform at any given time.  If I run it as a vi it works fine.   Once I use the Application Builder to create a dll form this vi, the “Call Library Function” does not report an error, it just runs and returns with no errors.  I put a dialog box in the beginning of the vi to validate the code is being executed.  It did not pop up, once I removed all the ni scope vis the dialog box pops up.  I do not have a clue as to how approach debugging this.  Any help would be much appreciated!
Rich
(2,343 Views)
Nevermind
(2,331 Views)
