Creating a file periodically without any user input
I am trying to create a file without having the user tell it where to go or what to call it. I have it set up to make its own name using the date. I thought it was set up to run automatically but when I run the program it comes up with a dialogue box for user input. Thank you for your time.
Ron Deavers, CLD
(2,856 Views)
In order to better understand the problem, can you please specify what the dialog box is asking for?
thanks
(2,854 Views)
Also, what function or VI are you using to do the file write.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,850 Views)
