Creating a new Event in event structure
nah man, i am using 8.6 only
Somil Gautam
Think Weird
Message 11 of 15
(748 Views)
Hi mike,
I have a vi and say few controls on it .Iwant to track event on one of the control in another vi. How can select it. Please refer my code to see what i have done.Also i can have only "value change" event.what should i do to access other events?
I wanted to track event of "Vr"  that is numeric control.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 12 of 15
(736 Views)
Hi Gaurav,
The Dynamic Event Registration node should be expandable to get other valid events available for that particular type of control. Did you try this?
- Partha ( CLD until Oct 2027 🙂 )
Message 13 of 15
(715 Views)
Hi parthabe,
Yes i tried. But no other option was available. Also did you c my code? Is it the right way to track the event of control that i want?
Message Edited by gak on 09-24-2009 01:58 AM
Gaurav k
CLD Certified !!!!!
Message 14 of 15
(712 Views)
I m not sure of how to track an event of a Ctl inside another VI.
But I m sure that the Dynamic Events Registration node is expandable & you can configure more events.
Message 15 of 15
(703 Views)
