Creating a progress bar
Your are not really clarifying anything.
@me1ody wrote:
One iteration depends on the time I run the program. I had N as 100 maximum in the for loop.
I was asking about a typical duration of an iteration, not their count. If the duration depends on the time of day, give a typical range.
@me1ody wrote:
Until know I haven't used property nodes. But that solution works perfect ... took me some time to find our that I have to change it to accept input parameters 😄
I don't understand how property nodes are a "solution". Solution to what? Change what? What kind of property nodes? Are you talking about value property nodes? If you are using value property nodes inside inner loops, you are probably doing it wrong. Can you give an example of what you consider a "solution"? I am curious. 😄
Message 11 of 11
(436 Views)
