Creating an AVI file
Hello.  I am trying to save output from a video camera to an AVI file.  The trick is that the user can choose to view the output OR view and record.  My problem is that I get an error whenever the "record" button is pushed due to the "Create AVI" vi call being called on every iteration (See below).  Any ideas how I can fix this... is there a best practise for this?  Thanks!
(2,991 Views)
Well, let's see....   How about moving the "IMAQ  AVI Create" outside the loop??? Smiley Wink
Put it in front and pass in just the reference.
EDIT: Not sure on the AVI stuff but you should probably close that reference as well...  after the loop.Smiley Happy
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,978 Views)
Good Advice.  I will try it.
Thanks.
(2,966 Views)
