Creating an array from 1 2D array of numbers and 1 1D array of timestamp values
How do you combine both  the array and the timevalues? Both have the same number of rows but I am not sure how to combine so that I can output a csv file. Thank you. (I transpose the 2D array so that it has 3 columns of y data points, with y number of timestamps)
(1,674 Views)
Accepted by topic author Programming_beginner
Hi beginner,
Simple solution: convert to timestamp array to a DBL array using the ToDBL function. Then prepend the additional row/column as discussed in your other thread(s)!
Warning: this result may not fit with your requirements as it converts the timestamp to the number of seconds since LabVIEW epoch.
So what are your requirements?
(1,671 Views)
will try that. Thank you.
(1,664 Views)
Here are my timestamp values. If I use a DBL function, it just outputs an array of constant numbers.
Is there any other way?
(1,613 Views)
Also, I would like to insert a column heading (1D array of strings), but the data type just doesn't match.
EDIT: Just decide to call multiple write to csv (one for string type, then the other with just numeric data with append set to True)
(1,609 Views)
Hi Beginner,
Did you read my previous message carefully?
I explained "Converting timestamps to DBL gives the number of seconds since LabVIEW epoch" - do you understand that sentence? Did you read the LabVIEW help on timestamps?
(And no: when the timestamps differ, then you will NOT get an array of constant numbers.)
I asked for your requirements, but you didn't provide them!
You can also convert the timestamps to strings: I recommend to read ISO8601…
(1,591 Views)
