Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
2
Creating an array via two cases element-by-element
Re: Creating an array via two cases element-by-element
Chris_Co
Member
12-05-2006
08:32 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
Do you want both accels on the same graph sharing the packet for the X values? I was confused why you had 2 graphs in your attached VI.
Well if you want them on one graph, then try the attached.
Chris Co
implementation4[1]12.vi 23 KB
1
Kudo
Message
11
of 14
(1,000 Views)
Reply
Ryan_H1
Member
Author
12-05-2006
09:46 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Ah, excellent Chris, thank you! As for the two graphs, I have to plot all values where "Mote" is 75 on one graph, and the values where "Mote" is 1 on the other. It's confusing I know, but don't shoot the developer.
Ryan
0
Kudos
Message
12
of 14
(993 Views)
Reply
altenbach
Knight of NI
12-05-2006
12:05 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Here's a simple modification that plots "mote 1" data and "mote 75" data on seperate graphs.
LabVIEW Champion
implementation4_MOD.vi 29 KB
1
Kudo
Message
13
of 14
(983 Views)
Reply
Ryan_H1
Member
Author
12-05-2006
12:26 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Yep, I actually had almost exactly what you did this time around. Thank you all so much, once again.
Ryan
0
Kudos
Message
14
of 14
(976 Views)
Reply
2
All Forum Topics
Previous Topic
Next Topic
