Creating an array with different data types
Hi RENN,
did you try Andreys suggestion?
Mike
Message Edited by MikeS81 on 05-04-2009 01:42 PM
Message 11 of 18
(4,442 Views)
yes mike
thanks for your quick reply
i need a control where i can edit values.
please see the vi attached.
thanks
Message Edited by RENN on 05-04-2009 07:38 AM
Kudos always welcome for helpful posts 🙂
Message 12 of 18
(4,431 Views)
Hi RENN,
in this case i think it would be a good solution to use a table as seen in your image. All your values are strings then. You can use a seperate array to store the types.
Hope it helps.
Mike
Message 13 of 18
(4,420 Views)
 you mean is it better to convert the string data type(eg-numbers in table) to intiger using one of the string/Number conversion function?
i'm actually using a table now. some columns are intended for numbers. but if the end user inserts some letters in the column intended for  numbers (string datatype) these functions returns zero.
Message Edited by RENN on 05-04-2009 07:55 AM
Message Edited by RENN on 05-04-2009 07:57 AM
Message 14 of 18
(4,416 Views)
Hi RENN,
i'm not sure what you mean. I think it's a better presentation. It looks better if you use a table instead of a big array of cluster of ... 🙂
Mike
Message 15 of 18
(4,410 Views)
thanks mike 🙂
could you please clarify what do you mean by a seperate array of datatypes?
could you please giv me an example vi?
Message Edited by RENN on 05-04-2009 08:01 AM
Message 16 of 18
(4,407 Views)
hai , i need to make an 2d array with differnt datatype in different column (eg: numeric in first column enum in second column string in 3rd column).
Is there any possibility to make ...
Waiting for reply
praveen
Message 17 of 18
(3,946 Views)
I would make a 1D array of clusters, where the cluster contains a numeric, an enum, and a string, Arrange the cluster elements horizontally and resize the array vertically.
See also this idea.
Message 18 of 18
(3,913 Views)
