Creating an executable "exe" - Missing external functions
Hello everyone,
my problem is the following:
I would like to create an executable data (.exe) from a VI.
This VI consists of several sub-VIs
I use LabVIEW 2023 Q1
After creating the exe, LabVIEW shows that the program has problems.
The following snip shows the error message:
When I run the the VI with LabVIEW then everything works fine.
The problem only occurs when I start the program by the exe.
In the following I desribe how I created the "exe"
Step 1: Open the VI I want to create an exe from
Step 2: Creating a Project
Project -> Create Project -> Blank Project
Adding my VI to the Project
After that I saved the project in a folder called Test008
In the Project Explorer all Sub-VIs are shown, also the VIs which are missing (see error message)
Step 3: Creating the Exe
Right Click on Build Specification -> New -> Application (EXE)
Source Files:
Destinations (Default Settings):
Source File Settings (Default Settings):
I have not made any changes to the other settings.
I would be very happy if someone can help me with that issue.
Unfortunately I do not have a lot of LabVIEW knowledge 😞
Kind Regards
Chris
(1,958 Views)
Your sub VIs use an external library that is not automatically included in the build. The driver probably comes with instructions how to deploy it in a built executable. Have a look in the manual.
Also see which point of this article applies to you: LabVIEW Executable Cannot Find DLL
(1,944 Views)
Accepted by topic author Lacuh
Thank you very much for your support.
I was able to solve the problem. I would like to briefly describe my approach
I used the explanations from your linked page: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000004AXDSA2&l=de-DE
I clicked on the LINK "project's dependencies"
The following section solved my problem:
When I read this, I thought to myself that a "dll" is probably not found because it is called by another dll, just like in the example.
I opened the folder where the Vis are located (Yellow) and added every data which I have found there to the project (see red)
Then I added these data to the section "Always included"
I clicked "Build" and my Exe worked 🙂
The "dlls" would probably have been enough to solve this problem.
I hope someone can benefit from my problem here in the future
Kind regards
Chris
(1,887 Views)
