Creating certified instrument drivers
Hello
Is it a requirement of certified drivers that they use VISA?
Can I create drivers using vendor-specific DLL functions and get them certified?
Robin
(2,941 Views)
I would assume that you've looked at the requirements. It states "Use the VISA I/O library to communicate over the GPIB, VXIbus, Serial, USB, PXI, and TCP/IP bus interfaces." and this is required.
Imho, one of the huge advantages of LabVIEW drivers is that the source code is available. You can modify the driver or fix bugs (and there will be bugs). Placing a wrapper around a dll defeats all of that and should be avoided. You are of course, free to create a driver with any method you like but personally, I would not define a wrapper type driver as LabVIEW Plug and Play.
(2,931 Views)
