Creating customized run-time menus
I am trying to create a customized run-time menu when I right click on a tree control. I can disable the existing run-time/pop-up menu but would like the ability to use a different customized menu.
I can simulate a run-time menu by using creating a VI that functions in a manner similar to the menu but would prefer the ability to create and process and customized run-time/pop-up/floating menu.
The menu is always of a fixed size with all items enabled. I do not need the ability to modify this menu within the application.
(3,141 Views)
There is an LTR article by David Ritter called "Contextual Pop-Up Menu Programming" that shows a method similar to yours. It is well worth a look.
-Jim
(3,141 Views)
Thanks.
It looks like the approach I have taken in the past and will continue to use until NI adds the feature in LabVIEW.
--Randy
(3,141 Views)
There is a 'toolkit' made by me that creates popup menus. Perhaps someone
can send it to you (I've send it to several people). I cannot send it to
you, the code belongs to my old employer (although I've send several copies
for free)...
Wiebe.
"RGSchmidt" wrote in message
news:506500000005000000FB380100-1066448259000@exchange.ni.com...
> Thanks.
> --Randy
(3,141 Views)
