Creating global controls
I was wondering how I would go about creating a global control. I am not sure what is the conventional meaning of a global control, but I am specifically looking for a control that bypasses structures so that I can instruct an infinite loop inside a case structure to stop from outside the case structure. Thanks.
Andre
Message 1 of 8
(5,479 Views)
To make a global, you'd want to check for a change on the control then wire the control into a Global Variable.  A global variable in LabVIEW is a variable that can be used anywhere in your project.
Message 2 of 8
(5,473 Views)
And if you just need access to this value within a single VI, another option is to create local variables of a front panel control.  I've used this trick before...make a hidden control on the front panel, and use local variables (and its terminal) to share a value between parallel loops on my diagram.
If you need access to the value in multiple VIs, however, the previous suggestion of using a Global Variable is the easiest approach.  Just watch out for race conditions...
-D
Message 3 of 8
(5,465 Views)
Do a search for Functional Globals (Also called AE's or Action Engines).  They are a better way to implement what you want to do over a global control.  Another method is to use a queue.  But for what you are describing, the Functional Global is the easier approach.
Jon D
Certified LabVIEW Developer.
Message 4 of 8
(5,464 Views)
Thank you for all your suggestions, however, my program still cannot perform the tasks I want. I can't seem to figure out how to use the global/local variables for my purpose. Perhaps I don't completely understand your advice so I created a very simplified program so that I can explain what I want to do. My aim is to start this program with the numeric value of 0 on the front panel, once I begin executing the while loop I want to be able to change that numeric value to 2 and stop the while loop. For my program I need for this control to be outside the while loop, and it seems once I have started looping nothing outside the loop executes anymore. I want to bypass this. Could you please demonstrate how I can use global/local variables to achieve this goal. Thank you.
Message 5 of 8
(5,415 Views)
A very simple example using a functional global / AE is attached.  Let me know if you have any questions.
Jon D
Message 6 of 8
(5,394 Views)
Thanks again for your help, but I was wondering if I could ask one more favour of you. I only have Labview 8.2, would it be possible to convert your files so that I can view them using this earlier version of Labview. Thanks.
Andre
Message 7 of 8
(5,390 Views)
Done.
Jon D
Message 8 of 8
(5,383 Views)
