Creating installer asks for unknown distribution
I'm creating an installer (Labview 9) for a Windows executable that uses serial ports.
As "Additional installers" i'm adding LV9 Runtime Engine, NI-Serial and NI-VISA Runtime. Is that correct?
But the main problem is: when i try to build the installer i get error "LabVIEW cannot locate the source installer for a component necessary to build this installer", and it pretends "National Instruments Device Drivers - November 2009" distribution. I tried to insert all NI Developer Suite DVDs from 3rd and 4th quarter 2009 updates, which i previously used to install NI stuff on this PC, but none works...
(2,919 Views)
I just ran into this problem (but with 8.5 not 9). It should be on one of the CDs. I don't know how the 2009 CDs are set up, but with 8.5 I put the main CD in that included everything on it (drivers etc). Then when this error came up, I browsed for the location. I went into drive(whatever drive letter is your cd drive) and looked in the signal express folder. In there you will find the file nidist.id. This is the file you need
(2,915 Views)
