Creating new objects on the Front Panel at runtime.
@Hooovahh wrote:
@BertMcMahan wrote:
Unfortunately I can't seem to find it 😞 I kiiinda remember it being Hooovahh, but my Google search is failing me.
I think this is what you are talking about.  I called it Multi Panel Interface.
https://youtu.be/bqNVbSn7nKg
Source on LAVAG.   It never got very far and I never used it for a real project.  I wanted to use a publisher subscriber model using User Events for the data.
I have made a tree based sequence editor before.
I followed a model similar to TestStand.  Steps on the left, sequence on the right.  You drag around steps into and out of loops, have gotos (as shown by arrows which is a 2D Picture control).  Each step can have individual conditions or limits to do things too.  The 2D Picture controls are the best.  You can make them do absolutely anything, assuming you have enough time to make it.  Some times I get stuck and just can't get a solution without them.  Making a UI look like a dynamically made thing, can be done with those.  I made a Ribbon Interface years ago which could have an unlimited number of buttons and tabs using it.  That one is a bit more polished but I also never used it on a real project.
Wow, that is impressive. I'm going to spend a day or two looking at that.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 21 of 22
(769 Views)
Yep, that's the one I remembered! Thanks Hooovahh. Glad I was able to attribute it correctly. I thought you'd posted it here so that's why I couldn't find the thread again.
Message 22 of 22
(753 Views)
