Creating password for gvi (LabVIEW NXG)
Hi guys,
I'm learning LabVIEW NXG at the Moment.
How can I protect LabVIEW NXG file (*gvi) with a password?.
Muaadh
Message 1 of 19
(4,271 Views)
It's a sad news for us that it seems LabVIEW NXG doesn't provide password protection feature.
PasswordProtectionNotSupported
If neither solution meets the requirements of your application, do not migrate to LabVIEW NXG at this time.
Certified LabVIEW Developer
GCentral
Message 2 of 19
(4,222 Views)
It's really a sad news. Can the block diagram be deactivated ?
Message 3 of 19
(4,203 Views)
Note that CG doesn't have a real diagram protection either. The password doesn't encrypt the diagram. (If it was encrypted, LabVIEW would need the password to import older versions, or when converting 32 <-> 64 bit, or Linux (incl RT) <-> Windows). The password is checked, and LabVIEW won't open the diagram if there is no match. So, your IP is not really protected. And this is really the only possibility in CG, because the diagram is needed for the conversion.
In NXG, I think you are advised to make a package (a gll, IIRC). If I understand correctly, this package will not include source code, but isn't exactly compiled code. So LabVIEW should be capable of opening and using the package in newer NXG versions and for LV RT, but there is no source.
Note that I'm not even sure if this is possible in NXG 4.0. This information is what I got from going to CLA summits, NIWeeks and NIDays.
Message 4 of 19
(4,198 Views)
I think it's  possible to deactivate the diagram...But I don't know  how?
Look at the pic. ==>
Message 5 of 19
(4,190 Views)
Check the origin of the gvi.
Is it by any chance in a gll?
Message 6 of 19
(4,177 Views)
I think the proper term here is a "Component".  Packages are a distribution vehicle.  The GLL is basically a replacement for a PPL (Packed Project Library).  I have not played with NXG nearly enough to give any real commentary beyond that.
Message 7 of 19
(4,166 Views)
That might very well be. But aren't PPLs locked for editing? So wouldn't that be a substitute for password protection? Or maybe actually a better choice.
I guess if OP follows that locked gvi, he'll find out.
Me neither. But so few of us have, and I feel even CG knowledge helps a little bit. If only to get things moving.
Message 8 of 19
(4,160 Views)
I wasn't arguing that GLLs are not the way to go.  In fact, I think they are what the OP wants.  I just wanted to make sure we were using the right terminology.
PPLs (and I assume GLLs) are fully compiled and contain no source.  So, yes, editing is locked.  But you can enable debugging, which will allow the block diagrams to be shown.
Message 9 of 19
(4,152 Views)
Didn't know that. So I guess the diagram is still available, and could potentially be copied? I mean with heavy scripting or hacking?
Message 10 of 19
(4,148 Views)
