Creating pattern for matching problem
Hi all,
I need to cut from the string specified part. It must be substring begins with $ and with the carrige return character at the end. Besides it may consist of any characters in the middle. I'm trying to use Match Pattern.vi but I've got problems with pattern creation. Cases with \$+CR or something like that doesn't work.
Help meSmiley Indifferent
(3,181 Views)
Hi Err,
I attached a simple example. It's straight forward, using two "Match Pattern" functions...
Message Edited by GerdW on 09-11-2007 11:30 AM
(3,176 Views)
try to use "Search/Split String" on the "adicional strings functions".
I tried here and worked with your example.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,174 Views)
my solvation here:
PS I use "x" instead of CR
Message Edited by Err on 09-11-2007 05:00 AM
(3,166 Views)
