Creating "Smart" or contextual buttons
Hi all,
I have a very cluttered GUI and it's full of buttons inside a case structure. I was wondering if there was a way to selectively show buttons from the selected case.
For example, I have "thumb," "index," and "MRP" cases in a ring selector. As you will see in the attachment, I have three sets of buttons, one for each case. How do I only show the appropriate buttons for the case when the case is selected, and hide (or gray out, even... anything to show they're not usable) the others?
Thanks!
(3,289 Views)
Try a tab control.
(3,284 Views)
I'm not sure if I understand the problem correctly, but there are tricks you could do.  The simplest is to use a TAB control which displays a group of controls & indicators based on certain selections.  The selection would index the appropriate TAB page.
Another trick is to use a combination of hide / display controls along with super-imposed controls (or indicators).  This one would have to be used with a lot of care, and therefore it is not recommended..  Why mentioning it?  Well, it is an approach that I have had to use in order to meet a design specification for a particular client.
R
(3,281 Views)
Got it guys, thanks a lot! 🙂
(3,277 Views)
