Creating the same program in one file
Hi
I would like to point out that I am new in Labview and i got one problem, which seems simple to solve. I have program which will count gummy bears. My target is to open this program 2 times, to select 2 different images and compare them and then point out which picture has more red gummies. However, when i copy all block diagram to create second attempt, i got only one, last image which i chose. How can I upload two images to be displayed side by side and then compared?
(1,710 Views)
You should make just one program that can open two images.
=== Engineer Ambiguously ===
(1,676 Views)
To possibly scale your program further, just use array of images as your input, then run calculations in a for loop and return the largest number (or index of image).
(1,654 Views)
@AeroSoul wrote:
On a side note, your shift register construct is exactly the same as just autoindexing at an output tunnel.
For a more "in place" solutions (beneficial if the input array is gigantic), it would be sufficient to keep the max and max index in a shift register and update if a new max is found (max initializes as -inf and index as -1).
(1,624 Views)
