Creation and understanding of custom invoke nodes
could I create somehow a custom invoke node? And is it possible to check the code behind of LV invoke nodes? For example I would like to understand how GObject.classOperator.traverse works, but it interested me generally (for any invoke node).
Balint
Message 1 of 9
(4,337 Views)
Hi ViltBalint,
you can create "custom" propertynodes or methods for XControls…
(LabVIEW comes with an example for a XControl!)
Message 2 of 9
(4,329 Views)
Hi GerdW,
thanks the example, I understand one of part my question. Have you any idea, how could I see, what code will be executed behind the build in LV invoke nodes? Or is that now allowed for users?
Message 3 of 9
(4,309 Views)
Hi ViltBalint,
Well, that would be the same as asking "What's the code behind the BuildArray node?"…
They are LabVIEW functions and are provided "as is". You can always read the LabVIEW help to understand how they work…
Message 4 of 9
(4,303 Views)
So the tracing is not available between property node and code (regardless of code is open source or not)?
Message 5 of 9
(4,290 Views)
Accepted by topic author ViltBalint
Hi ViltBalint,
Well, property nodes simply read or set properties of a control: all they do is accessing data inside a datastructure related to that control.
As LabVIEW is closed source I don't think NI will tell you any details about those datastructures…
For methods: they do some more interesting stuff, but it's basically the same: NI will not tell you the implementation behind them…
Why do you even want to "check the code behind" those method nodes?
Message 6 of 9
(4,277 Views)
I would like to know exactly why execution time of Class.traverse is significantly slower in a bigger project. For example: I would like traverse GObjects on a VI, the VI has not any project dependency and it is a fast operation is a small project. BUT if I replace my VI to a larger project (of course with same dependency) the execution time will be increase, and I can not imagine why. Any idea?
Anyway thanks your help, I got answer for my original questions.
Balint
Message 7 of 9
(4,267 Views)
Inspied By Edgar Allen Poe "Annabelle Lee"
It was many and many of years ago when working with my PC
That a hint was offered that I did make for scripting code to see
I waited for others to ask what may and learn what I could glean
And to my surprise, none did ask save Ton and I gave him this bean
Since Scripting is now available, I will share the following.
I learned from "a little birdie" a way to unlock all of the locked code in LabVIEW. That hole has been long plugged but at the time I offered to unlock choice code and all they had to do was ask. TO my surprise only one person asked and what they asked for was exactly that function!
Here are two VIs that may be interesting.
Ben
Message 8 of 9
(4,244 Views)
Hi Ben,
thanks for the nice poem and hint 🙂
I know both of VIs that you linked, and "TRef Traverse.vi" contains that piece of code (see pic.), which behaves in different way in a small and a big project (realized that strange behavior just after feature integration 😕 ).
So I have currently two idea about that:
  • Traverse makes inside some project dependent operation (despite of it is unecessary (?))
  • General overhead in a big project because of resource (memory) management in LabVIEW
Do you have any idea?
Balint
Message 9 of 9
(4,202 Views)
