Creative Way to Post Front/Block Diagram in Word Document
Does anyone have a creative way to post Front/Block Diagram in Word Document in the same calibre as if I used SNAPIT.
Thanks in advance.
(2,837 Views)
You can use the report generation VIs (you should have a palette of them) to do this. If you want another way, have a look at the VI posted here.
___________________
Try to take over the world!
(2,829 Views)
Another option is to simply select the code, copy and paste it in word. It will be pasted as an image.
___________________
(2,826 Views)
Thanks. I will give it a try.
Selecting the code, does not give the best image because some things are chopped off or the whole diagram is not in the image.  Usually, I have to resort to "Print Save."
Message Edited by roboticstudent on 03-20-2006 10:41 AM
(2,817 Views)
