Crerate waveform from 2D array
I am working on a real time application which adds a new 1-d array at every 2mS, which gives resultant 2-D array. How can I convert this 2-D arry into wave form in minimum possible delay as application needs online data.
Message 1 of 8
(19,110 Views)
Hi
Are you trying to acquire the analog channels data?
Does each analog channels acquire samples in 1 D array format?
If you acquire data, I want to know what is your sample rate?
Message 2 of 8
(19,100 Views)
Accepted by topic author hmdesai
Here is one way. You need to add youer sampling frequency to the dt control and you may need to tranpose the data depending on how it is put together. The other way would be to convert the 1D arry to waveform before saing to a 2D array. Then make a 2D waveform instead.
Tim
GHSP
Message 3 of 8
(19,093 Views)
Hi Desai
Here is another way to create waveform which you can see live during the test. I hope this fulfill your requirements.
Message 4 of 8
(19,083 Views)
Message 5 of 8
(19,070 Views)
hi thanks for reply.
yes i m acquiring analog data in 1-D array format at100 Ksamples  at 2 mS. sample rate.
Message 6 of 8
(19,055 Views)
thanx buddy....
Message 7 of 8
(19,050 Views)
@Viru: hey can you show me how can i add time stamp in your method??
Message 8 of 8
(19,049 Views)
