Crio-9025 replacement
what is the recommended alternative for Crio-9025? I have a legacy system that needs to be replicated and recommissioned, however, since the system uses Crio-9025 which is no longer available can you suggest the best possible alternative for the same?
As per my understanding Crio-9035 is the closest replacement, can some please confirm if I am right?
(930 Views)
9035 is around for a while, maybe go for 9046? How many slots? 9045 is less temperature range, may be a bit cheaper.
https://www.ni.com/en-au/shop/category/compactrio-controllers.html?page=1&SlotCount=8&foc=1
(914 Views)
Thank you for your response, currently we require 8-Slots. In case more are required we will be using an expansion chassis.
(907 Views)
Accepted by topic author linu95k
The 904x and 905x series cRIOs are the latest generation cRIOs so I would recommend going with those. The 905x are generally the lower-cost options (relatively speaking) but if you're upgrading from a 9025 that may be all you need if you're just looking to run the same code on newer hardware.
The cRIO 903x series was a previous generation so I wouldn't recommend it for any new applications. You'll probably see that comparable 904x and 905x cRIOs are cheaper than the 903x counterparts anyway.
(891 Views)
