Cross Correlation Rxy problem
I am trying to cross correlate two signals, each with about 200 data points. both signals are correct and i can even see the lag between on the graphs. when i put the signals into the cross correlation vi my Rxy is in the thousands and the graph looks like a pointed triangle that goes up to the tens of thousands. is there some sort of normalization i have to do to the data? thanks
(3,212 Views)
Hello wally424,
It is quite normal for the cross correlation to be in the tens of thousands. Two methods of normalization are given in the following link:
Cross Correlation Normalization
You should be ending up with only about 400 data points on the x-axis. You mentioned yours is in the thousands; exactly how many are you getting?
If none of these suggestions help, or if I�m not correctly understanding your issue, please post the software and versions you are using, the applicable portions of your code, and any other information that may help, and I�ll be happy to look further into it.
Have a ni
ce day!
Robert M
Applications Engineer
Robert Mortensen
Software Engineer
(3,212 Views)
sorry, i figured it out a couple days ago. i found that a previous post that explained how to normalize it, since then its been working fine. thanks alot though.
(3,212 Views)
